cracked Tcase
I was parting out a 88 BII today for parts to use on my 89, one thing I wanted was the manual tcase.. after removing it I noticed the aluminum front adapter on the Tcase that bolts to the trans was cracked in several spots.. I called a few drive line & parts places.. & no ones has it.. does anyone have an idea where I can find this part?
Tcase is a Borg Warner 1350 Manual..
awesome, I was starting to get worried..lol
I have been calling driveline places all day.. no luck
I am in georgia, 30517.. shoot me a pic, & price shipped..
parting out the 88 BII if you need anything I don't let me know..
i have one that came from between an a4ld and 1354, i'm pretty sure its the same as what you need. if your interested pm me
the part I need is actually a part of the tcase. just bolts to the front.. was told its called a front adapter, here is a picture of the part.
oh, no i dont have that, i have a complete 1354e t-case but i need to hold onto that for a spare, i have the extension housing for the trans, it bolts to the back of the transmission and then the tcase bolts to it right where that part is you need. sorry
i have one for an electrical t-case, i think it should fit fine
Yeah, you can find 3 of them in my T-case spare parts bin.
They made 3 different front plates that will fit:
1- Early 13-50 - has 4 planet gears, tapped for standard bolts, and slightly weaker design (less meat around bolt holes).
2- late 13-50 - has 4 planet gears, tapped for metric bolts, and slightly stronger design. (also used on early 13-54s)
3- 13-54 - has 6 planet gears, metric bolts, same strength as #2.
(there may be more, the newest 1 I've had apart is a '99)
#1 +#2 will fit with no mods, other then using different bolts.
#3 will work with the right high/low range gear and shift fork.
The 4 planet gear isnt as strong as the 6 gear, but there are very few people who have broken the 4 gear setup.
Go with #2 for the easiest fix.
Oh yeah, it doesnt matter if its an electric shift or manual, either will fit.
1- Early 13-50 - has 4 planet gears, tapped for standard bolts, and slightly weaker design.
:icon_hornsup: your knowledge AND parts pile just keep amazing me :icon_rofl:
My garage is 21x13.5 and there is no usable space left. And you saw all the stuff I have here at the shop. I'm trying to get a 40' storage container like the one here for home, so I can have the garage back. The wife says NO, I said she can park her car in the garage then. :icon_rofl:
thanks for the info..
if one from a electric shift 1350 will work, I might have a good one on the 89,.. I haven't pulled it out to yet to see. but if you guys have an extra one, keep it handy, I may still need one..
here is a picture of the crack..
thanks again!
thanks again!
Yeah, the front plate from the '89 13-50 elec shift will fit your '88 manual shift 13-50. Its a direct bolt on.
