fourwheelford
I just spent the last hour reading about this crap and now I have a few questions about it.
1.My truck has a little under 101,000 miles on it how likely is a syncro failure if its not making any noise?
2.Its 90 degrees right now so im using 10w-30 castrol high mileage oil, will the thicker oil quicken the death of the syncro?
3.The truck does not see high RPMs(4000 grand is the max if im pulling a steep hill) but thats not often, do hi RPms quicken the death?
4.I bought the truck with 98,000 miles on it what is the likely hood that the syncro has already been replaced?
5.Because I stay in the city and my rpms usually sit below 2500 I should get a CEL before the syncro fails completely right?
6.With the alignment tool and a haynes on hand how difficult is this on a scale of 1-10 for a semi-good wrench turner?
Im just trying to get a good handle on this thing so I can understand it, I don't want to change the oil again because I just did about 300 miles ago but I will if I have to. I understand how the stupid thing works but hearing from a ford veteran or tech would be great, I don't even want to drive the truck because im so scared of it going out. I stethoscope it all the time and its quite as a church mouse but I don't have good luck with stuff like this. Any info is great thanks everyone
