- Dec 6, 2009
- maplevalley WA
- Automatic
Did anyone else have to bend their automatic transmission dip stick tube, so they could have enough clearance for turning the distributor?
You can always move the timing gear on the dizzy back a couple of teeth. Slowly lift the dizzy up until you can turn it back or forward a couple of teeth. you wont be able to push it all the way down bur lightly preass down on the dizzy with the rotor off so it dont grab your hand and have someone click the ignition until the shaft lines up with the pump then it will slide all the way down. Or you can advance all the wires in one direction to get the same result.
