Couple of 2000 Ranger Questions
kamps989
St. Paul, Minnesota
Wondering if there is anyway that I can adjust my tailgate (stepside bed) because in the bottom right it overlaps slightly on the side panel and is rubbing the paint off. And I only have one fog-light (in the market for the other one) and it wont stay on unless I am holding the button in, any possible solutions? Thanks.
There should be a little bit of side to side play with the tale gate. Let it down and give it a little wack with a rubber mallet and see if that does the trick.
Remember, if brute force isn't working, you're not using enough!
Welcome to TRS
My tailgate kept wandering over to the driverside (no matter how many times I centered it) so I just put a ziptie on the driverside guide and that centered it. Haven't had an issue with it since.
As far as the fog lamp issue, maybe a new switch?
