speaste
- Aug 12, 2008
Hi all,
I have an 84 Ford Ranger 2.8L V6 with a manual transmission. I just got the truck and it's a major project with a bunch of stuff to fix. I have two questions related to this transmission:
1) How can I tell if the transmission is a 5 speed or 4 speed? If it's a 5 speed I can't find 5th with the shifter so it's gone. The shifter knob has been changed out with some aftermarket shifter. On the drivers side visor, there is instructions for shifting a 5 speed not a 4 speed so I started thinking messed up 5 speed but as Allan points out, a used truck with no history could have a different transmission. Is there a model or serial number on the transmission I can read when it's installed? It has the ribbed pan but not sure if this indicates one vs the other.
2) The transmission/clutch is making a noise that sounds almost like a rubbing or low rumbling when the clutch pedal is released...even when transmission is in neutral. When I push the pedal to the floor, noise nearly or completely goes away. Any suggestions as to potential causes? (saving the fact that 5th gear is all over the bottom of the transmission pan if it is a 5 speed
Thanks guys!
Thanks guys!
