lawmaster891
ok first off i need some help on the egr. i have looked and can only find people arguing to leave it on and take it off. i want mine off. i have it off and a block off plate made. there is another sensor right by the egr that has a vacuum going from the egr to it and another vacuum tube coming from somewhere else. can i just attach the vacuum line to the sensor to block it off? also the egr tube broke right outside the exhaust manifold and i have tried everything to get it out. is there any other way to plug the hole?
Next i have a very small bit of coolant coming from somewhere around the waterpump. any ideas on this?
Last i have some what looks like powersteering leak that is coming from around the pitman arm. ideas?
All of these are not bad leaks but i would still like to fix them.
