Raymond
- Nov 15, 2008
Could I put a 88 axle flang on a 94 Rear end. The rear end that I am going to pick up is exactly the same as the one I broke. The only diferance is the axle flang on the 94 is a larger U joint. Will I be able to use the 88 rear flang on the 94 axle? I have a supercab, The other truck is a reg cab. so I can't use the 94 drive shaft.
Thanks Guys
Thanks Guys
