$1200 truck going on 11 years ago. Setup for a carb from the factory, converted to Duraspark by me several years ago (V8 ignition will be plug and play)
Truck is 4x4, 2.8 with the floor shift A4LD, BW1350M t-case, D28 front and 7.5 rear.
Truck will be 4x4, 5.0, with floor shift C5, BW1350M t-case, D28 front (for the moment) and 8.8 rear.
Truck still sets in the same config as it always has been and the engine/trans/axle are waiting until spring.
Just going by memory (I do have a 3 ring binder at home with all my receipts on my current engine)
$200 '87 non HO roller 302, came with dual sump pan and serp belt setup
$200 or $250 V8 C5 with RBV C5 tailhousing installed, and shifter (didn't think to ask about the stinkin bezel though)
$50 oil pan gasket
$80 valve cover gasket
$10 front seal
$15 rear seal
$25 reman waterpump
$170 Weiand Stealth intake manifold
$60 reman Duraspark dizzy
$25 oil filter adaptors (I am going to make my own hoses)
$5 rotor
$15 adaptor ring
$20 distributor cap
$20 Edelbrock valve covers
$20 Mallery oil pump
$10 Mallery oil pump driveshaft
$30 Mallery oil pump pickup
$40 blue 9mm Ford Racing plug wires (cut to length)
$15 spark plug loom kit
$25 SN-95 Mustang motor mounts x2
$30 C5 Ranger transmission mount
$30 C5 Tranny filter
$40 Mr Gasket electric fuel pump
$10 aluminum water neck
$5 thermostat
$30 (might be high) new temp and oil pressure senders
$40 Cloyes double roller timing set
7x 10W-30 Motorcraft oil for about $3/qt, I got a couple extras to keep on hand.
Free 4.0 automatic Explorer radiator with a slow leak to check if it will keep it cool before I drop $200 on a new one.
$100 31 spline 3.73 8.8 L/S with disc brakes and leaf springs all out of an Explorer, not really part of the swap itself but something to keep in mind when adding power is putting it to the ground and not breaking stuff.
What I need to get yet:
$20 Edelbrock air filter housing/filter (to go with my valve covers)
$315 Edelbrock 1403 4bbl carburetor (or comparable used, 500cfm carbs are not that common used though...)
Accessory drivebelt
Power steering pump (tired of the whiner in the truck now)
?? some sort of fan and shroud
Driveshafts ??
Radiator hoses
Spark plugs
Possibly headers (if so it will be Hedman 88400's which are about $160)
True dual 2.25" exhaust - roughly $200 in pipe
$30 x2 Thrush glasspacks
$50 x2 stainless tips
Tranny fluid, dunno what that runs.
Going to try to use my Ranger alternator... hopefully it works.
Who knows what else will pop up...
It adds up quick and plan for misadventures
