King17
i was wondering if anybody had 3" lowered ibeams and new the correct degree to set the wheels straight.
Using the Dream Beams: What if the truck had a 2.3 but it was changed to a 4.0? Should the springs and eccentrics from the 4.0 truck be installed into the one with the 2.3 or does it matter?
if you have a 89-97 go to napa and get the eccentrics part # 264-3950 +-4 degree camber caster adjusters and then take the truck to an alignment shop. Absolutly no reason the truck cant be aligned perfict.
The part number I listed above is +-4 degrees camber/caster it is the max you can get for a ranger.
