okay well I got to play with my wrenches again this past weekend. I ordered a trigger wheel from DIY autotune after being assured that it was tested with a factory 91 ford escort VR sensor. Naturally I ordered that particular sensor also. The DIYautotune wheel is a nice unit imo. I fitted it with a little cutting work to my pulleys (between the alternator/g-charger drive pulley and the waterpump/ac pulley.) Having the half inch center hole was nice to center up the trigger wheel to mark my points to put FHCS holes in the wheel to bolt it flush to the crank damper. I then put then transferred the holes, tapped them (the ones in the damper) and countersunk the trigger wheel holes. All in all a simple process that takes a bit of time in an effort to be careful. I realize the damper is probably not the best place for it however it works and if it does create a bit of havoc the hole is still the right size to weld it to the back of the crankpulley (didn't have access to the welder at that time).
Additionally, I refit my repaired fuel lines. Basically I cut back the old nylon lines to the point just after the filter such that all the factory bends were retained (that portion of the lines were still in great shape). I then used some matching size new nylon fuel line I bought off Amazon connecting the ends with the barbed brass repair fittings. The brass fittings are a bit of a pain to work the hose onto, even if you do the recommended boiling. I found and easier way to fit them to the first half of the line, chuck the fitting in a drill and spin the drill SLOWLY feeding the brass fitting into the nylon line. The frictional heat generated heats up the end of the line to just the right point for it to slip over and then when it cools it seals and conforms to the barbs. I did pressurize the system and check for leaks and well, no leaks! Fitting the other end of the new hose was more involved and I did a bit of boiling and a lot of twisting by hand to finally get the hose all the way onto the fitting. It takes time but do take your time and don't be tempted to use pliers, these will gall the lines up pretty bad and might be deep enough to leak. I used a rubber shoed bar clamp (the ones for wood) to hold the end with the fitting in place and that worked well without chewing into the lines.
This weekends agenda is lining up the VR sensor, finding a good spot for the coil, and hopefully loading a basemap to start it up.
