Pistons23
so yesterday i was checking the coolant level. when i pulled the rad cap i noticed a orangish-yellow buildup around the radiator fill neck. i also noticed the fluid in the reservior was a bit orange. when i flushed the sytem a few years ago i used prestone 50/50. the green stuff. this truck sits quite a bit. im guessing its rust. anyone think otherwise?
today i went and bought prestone super radiator cleaner($5.99 at autozone), prestone 50/50 antifreeze($8 at walmart), prestone concentrate antifreeze($10 at walmart) and the prestone flush/fill kit($3.99 at autozone). heres what i plan to do. drain the radiator. then fill it up with water. let it run for a bit with the heater on. drain it again. then pour in the radiator cleaner. top off the rad with water. drive it for the recomended 3-6 hours. drain that bad boy out and back flush the system. then ill dump the prestone concentrate in there. then fill the empty jug with water and hten dump that in the rad. so i get the 50/50 mix. then ill top it off with the prestone 50/50. will that work fine? any suggestions?
will regular water from the hose be fine or do i have to buy distilled water? or how about the filtered water from my fridge?
