Coolant system knocking upper rad hose pulses
Well I have just changed it about a year ago, no leaking out of weep hole and turned freely, when I had it off a few days ago
But that started with the change?
It makes me think one of the pump fins is damaged. Like when you put a ceiling fan up amd one blade is weighted differently, it makes the fan shake
The only things that have anything to do with coolant flow is the pump or the thermostat.
Maybe the thermostat is just opening and closing oddly fast?
Im also having this thumping. Im installing a new water pump, hoses and heater core to see if that fixes it. WIll have it done today. will report if it cures the issue. 1994 4.0
Got everything swapped. Heater core, thermostat and water pump. Gauge doesn’t fluctuate really bad like it did and so far no thumps.
