My temp guage is registering very low, changed sensor no change...
Coolant overflowing the puke tank...
Newer waterpump...
Blackish looking residue floating in coolant...
Top radiator hose warm lower cold, radiator cold....
Hat works but not well and not at all at idle...
Some histrory here...
Replaced both heads, all was well for a month, suddenly missing, lost compression, burnt plug, coolant nasty black looking...
Had junker engine installed...
Now i have previously mentioned symptoms...
I pulled heads off the motor that was pulled, cracked head and intake valve missing a quarter of its top...
The coolant ports are lined thickly with some fine dark grey or blackish powdery residue... this residue matches the nasty looking head gaskets that looks like its just disintegrating...
my thoughts are that the cheap head gaskets i bought failed horribly and filled the head coolant ports causing the head to overheat and crack...
shop that swapped out the motors didnt flush the radiator and heater core and therefore coolant wont flow thru radiator... barely flows thru heater core...
this also means that residue has gotten into the head ports like before...
... what are the chances of flushing all this crap out of the heads and heater core? I dont wanna tear diwn the junker motor... thats why i put it in so i can work on the motor that just came out...
I can easlily replace the radiator but i dont wanna do that just to crud it up trying to flush the rest of the system...
i need some help here!!!
Will a chemical flush get this crap out?
Newer waterpump...
