Coolant problems again....
mounties83
Ligonier
Alright so I fixed my leaking thermostat housing...(i think it was just a loose bolt) and the leaks stopped.....i drove it around everything seemed fine...started it up today and noticed its leaking coolant again and this time its coming from the radiator somewhere on the drivers side bottoms near the hose..hose is fine i checked it..so i think ill just go buy a radiator( found one at the junk yard for $60)...could this be in any connection with a intake gasket leak...check engine lights on for a lean code..i think its messing with the coolant system pressurizing it or something
