titanmax
- Feb 18, 2008
- Age
- 45
Just finished doing a full coolant flush on a 93 4.0 with 150,000 miles. Original water pump. All was fine, only removed the upper hose on the rad.. New coolant is in.. Noticed a constant drip from the I-beams coming down by the passenger motor mount... It is wet up behind the tension pulley, but I can not tell where it is coming from. Should I assume water pump, or is there something simplier I can do first?
Thanks...
Thanks...
