beenjammin
Ok, so I drained and flushed my cooling system a few weeks back. Drained out the radiator and in order to get the remainder of the old coolant out of the block I just popped off the lower radiator hose at the base of the radiator to drain it all out. My chiltons said nothing about a drain plug for the block and if there is one I have been unable to locate it.
Now I've got a slow leak from the lower radiator hose. I replaced the hose and installed the clamps that you turn the screw on to tighten instead of the the springy ones that were on there. It still has a slow leak where the hose connects at the base of the radiator and for the life of me I cannot figure out why its doing this. I'm thinking about moving the clamp a little closer to the lip of the connection that the hose plugs onto as maybe it will seal up a gap? I'm at a loss. Anyone have any pointers?
