coolant change
dheizer
Cobb Calif.
I have a 2007 ranger w/ manual tranny. I cant figure how to change the coolant. There is no radiator cap only a resivor cap. any able to help.
Thank You
Dale Heizer
Did you crawl under and look for a drain on the lower left or right of the radiator facing towards the engine?
I wouldn't try the drain cock on the radiator simply because I've had them cheap plastic things break off...you can drain the coolant by just cutting off, no, don't cut the hose...remove the hose from the pump by loosening the clamp and it will drain almost perfectly into a bucket...you probably shouldn't have to replace the hose but it would be an excellent time to do so if you have a spare $25...that's how much the hose was (CDN)...
