92 5 oh
- Sep 14, 2007
- Age
- 43
- Virginia Beach
1998
- Automatic
Hey everyone, my fiancée has a 01 civic, a few months ago we were driving home on the highway and I noticed the temp gauge was climbing to the red as we were pulling in to the driveway. There was coolant on the top of the radiator and it appeared that it was leaking out of the cap. So I replaced it since it was the original. Drove it for a few days and noticed it was still borderline overheating. Next I did a pressure test on the cooling system and cap. It held ~18psi for a few minutes and slowly bled off. I couldn't locate any coolant leaks anywhere. So I drove the car around a bit and realized it would lose coolant when driving or running it hard (as opposed to sitting at idle). This is when I figure out the coolant was being pushed in to the overflow and leaking out of. The upper radiator hose felt like it has quite a bit of pressure, I'm not sure how much but it was definitely more than when doing the pressure test. So I got a leak down kit and ran it on the motor cold twice, then let the motor idle for about 30 minutes and did another leak down after it was up to operating temp. All 3 tests showed no more than 15% leak down. I'm also not able to find any signs of oil in the coolant, coolant in the oil, the plugs don't seem contaminated and the exhaust doesn't smell different or smoke, the coolant isn't rusty or appear to have any garbage in it.
I went ahead and replaced the thermostat and flushed the cooling system. While doing so I noticed the low speed fan wasn't coming on at all. The fan switch (located in the thermostat housing) tested bad, so I replaced it and the fan started operating as expected. I thought the problem was fixed, but wasn't completely convinced since the coolant problem was happening at driving speeds. And as far as I know radiator fans don't work at speeds above ~25 mph. So I drove the car around town, errands and such for the last two weeks with no problems. Took it on the highway when possible too and drove it harder than my fiancée would. I was just thinking to myself that it's fixed.
I had to drive about an hour away for work yesterday so I took the civic. Did fine on the way there but as I'm pulling in to my destination I noticed the temp gauge was starting to creep up. Checked under the hood and sure enough, the over flow was full and starting to leak out of the top. So when I left for the day I added some water, then drove home. It did fine but as I pulling up to my house the gauge was creeping again and the over flow was full/starting to leak out.
So as best as I can tell, the problem happens when driving for extended periods (45+ minutes) and/or from extended higher RPM's. It doesn't have a tach but I'd guess running ~70 mph it's around 2800 RPM's.
The only thing I can think of doing at this point is to top off the cooling system again and run it in the driveway at 2500 rpm's for 45 minutes or until the coolant fills the over flow and then do a leak down. I'm not sure if these are symptoms of a failing head gasket, warped head or clogged cooling system?
I'd like to try and get this fixed over the weekend. Any other thoughts or suggestions?
Thanks and sorry for the novel.
Steven
Steven
