Anythings possible, but it wouldn't make much sense or be cost effective. You could sell your Ranger and buy a 4WD for less than it will cost to swap it over.
If your 2WD is an "Edge" or "Trailhead" model (has torsion bars up front), it may be doable.
If it has coil springs up front, then it's definitely a no-go (well unless you want to procure a solid beam front axle from a Jeep Wagoneer or other 4x4 and swap it under the front of your 2WD, then anything's possible).
For
