texas03042
- Jun 30, 2013
- Automatic
I trashed the converter and shaft by not having the converter seated right before bolting the trannie in. the trans is for a '96 2.3 and is the 4R44E.
as the trans is just a variant of the A4LD, will any A4LD converter and shaft fit? From any vehicle with the 'T' code on the door plate?
since there are no wires to the converter, I figure the 'lock up' is something that actually happens inside the trans, even thou it's called a 'lock up converter'.
or am I stuck with finding a year/engine specific part?
the local you-pull does not have the book that lists what fits what.
