The 2wd Edge and the 2wd Sport have the same frame and torsion bars as the 4wd '98+ Rangers. The standard 2wd Ranger has a completely different frame with coil springs.arent the 2wd edges about 1000X easier to convert to 4wd than a regular 2wd?
I have done the swap. Here's what you need:
4wd transmission
transfer case (manual is easier, electric requires you to change the dash harness)
front drive shaft(Older style manual transfer case takes an older style front driveshaft)
rear driveshaft
front axle
both front cv shafts
both spindles(with wheelbearings and ABS if required)
front rotors
Front axle with matching gears to your existing rearend
Rear axle mount on the frame(buy from a junkyard or make)
If you go with the electric transfer case you have to change the dash harness and body computer. The cluster is optional if you want the 4wd lights.
If you go manual transfer case you will need the shifter also.
I went the electric route but I had a complete wrecked parts truck. Of course this only applies if you have a tortion bas frame, not coil springs up front.
I think thats it.
