conversion plate???
rcwc28
tacoma washington
hi i got a 2.3 and i saw a web site posted here on trs about a adapter plate that will help me put a trans on my truck .. that will normally bolt to a 302 or a 289 . so if any can give me a shout out about that web site cause i cant find it again would be a great help thanx guys
Why would you want a tranny even weaker than a A4LD without the plus of overdrive?
They came in really early 2wd four cylinder Rangers from the factory, small cheap cars like Pintos too.
actually there waqs a posting on this site about useing a trans off of a 302 and a 289 i thought it was a c3 . i could be very well be wrong but im looking in to build options
It could have been the C4. I think I have heard of a select few four cylinder cars got them.
Don't remember what the rhyme or reason was though. :icon_confused:
btw this was posted by mercman a while back but it is worth showing again for all lima motors who wanna do a build
Hey,
Here's a couple links to places that make adapters that allow you to bolt your 4cyl to any trans with a windsor 3.8,300,302,5.0,351W,351C bolt pattern. I wish i had found these when I was building my bronco 2, lots more options.
http://www.cididit.com/index.htm
http://www.stinger-performance.com/suspensionparts.html
Too bad they are no longer available though.
You looked Summit, Jegs or Speedway Motors though?
Speedway has quite a bit of stuff for 2.3's. (or so it seemed as I was looking for SBF stuff in their catalog)
true one site doesnot sell the plate but it dose sell the flywheel for the conversion and cainfield dose still sell the plate and i'll deffinatly will check out summit too thanks for the info
