lukeburris53
- Dec 12, 2007
Heres the deal: I've got a 90 BII 4x4 with an A4LD. A4LD decided not to work anymore so it is currently on the ground with the electric transfer case, as well as the driveshafts. I don't want to fool with another automatic so a 5 speed will be going back in.
From what I understand (which could very well be wrong), there are two manual options to go behind the 2.9L. One is Mazda made, the other Mitsubishi. Apparently the Mitsu is 2" longer, therefore requiring a swap of driveshafts. Logically, I would prefer to have the Mazda one in this case. I've gather that the Mitsu has a drain pan on the bottom, the Mazda doesn't.
In the last few days ive been to 2 junkyards and looked at no less than 100 Rangers of BII's. Today I found 15 or so with a 2.9L and manual transmission. All of them had drain pans.
So I guess there were either very few 2.9L/Mazda 5spds or I just haven't looked hard enough.
The first question then, is all of that information true? Were there really two 5spd options behind the 2.9L? Does the A4LD to Mitsubishi require driveshafts being changed.
Most of the the transmissions I found were from Rangers. What Ranger cab/bed combo match the wheelbase of the BII. Thanks in advance..
