meatshieldchris
- Sep 29, 2009
Just recently bought what others thought was a beater ranger, and it turns out it's alot nicer.
When I bought the truck ('92 4x4 2.9L), I was told there was a leaking rear main seal. Oil appeared to be dripping from the right spot. Just took a closer look: it looks like there's a little gap between the bellhousing and the plate that's between the engine and bellhousing, to see what I assume is the back of the flywheel. The back of what I think is the flywheel is totally dry. I noticed most of the oil is accumulating on the oil pan side of the plate, near where the hump in the oil pan is for that end of the crank.
Can a rear main leak between the engine and the plate? Or will it usually leak into the bellhousing and leak on to the flywheel like I thought? My thought is that since the flywheel is dry, it's oil pan gasket.
There also looks like there's a rubber plug in the side of the bellhousing...any gotchas I should keep in mind if I pull that to take a closer look in the bellhousing?
