GingerKid
The m5od in my truck is hard to shift into gear sometime. It won't grind, but it won't go into gear until the rpm falls to where engine speed matches the speed of the trans. It doesn't do this all the time though. This is a slave cylinder going out right?
Edit: also when shifting to gears at low rpm (1000-1500) there is a growling kind of noise. The noise also goes away if I let off the throttle. I now it's not the throwout bearing since it only does it with the clutch engaged. Pilot bearing? Input shaft bearing?
