Computer
CarsonD
Arba, NC
Is there any way to make the computer in a 2002 3.0 let you go faster than 93 mph?
because..... i want to drag race at the local drag strip, but would it still be legal on the road?
It's got blue RACING stripes on it. Obviously it's fast now.
If you're drag racing a 3.0 on 1/4 mile, don't worry about going over 93.
you can hit 93MPH in the 1/4 mile?
:icon_rofl:
First off I thought the limiter hit at 97mph or maybe thats just the 4.0. anyway to answer your question. The only way to get above 93mph would be to put a chip in it. Not a cheap chip either. My advice is do not waste your money on a chip I would just swap in a 302 or something. Rangers unless modifyed for pro-street (RACING STRIPES DON'T COUNT) are not meant to go that fast.
actually, the speed limiter is triggered on ford trucks at 92-point-something. our speedometers just arent that accurate (the needle itself is several MPH wide), and a speed limited isnt perfect (its hard to slow an engine thats at WOT down smoothly enough for the driver to maintain control).
ive run my 3300lb truck in the 1/4 mile before and it runs...the 1/4 mile.
put it this way...i would need over 200HP at the wheels (not the stock 120HP or so) to enter a trap speed above 93MPH. you 2wd guys are lighter, but not by THAT much.
if you arent sucking giggle gas or boosted, you arent hitting the speed limiter in the 1/4 mile with a 3.0 (or 4.0 SOHC for that matter).
I have a friend that has one of those Chevy S-10 extremes with the 4.3. It's stock. I have seen him hit his limiter in the 1/4 mile. I would imagine the 4.0 in a 2wd would do it as well. Then again I do not know the differences between the 4.0 and the 4.3.
the 4.3 is a torque MONSTER. it makes the 4.0 OHV and SOHC look like soft little baby kittens. it made up to 190 HP and an ungodly 245ft/lbs of torque. by contrast, the 4.0 OHV makes a meensy 160HP with 220ft/lbs. even the SOHC is only rated at 238ft/lbs...but with more HP at 207.
on top of that, most of the RWD s-10 trims are lighter than most ranger RWD trims. i also have no idea what chevys speed limiter is set at.
but, those are all flywheel HP figures. your typical RWD drive trane will soak up roughly 15% of your flywheel HP (more for an auto). so even a SOHC ranger is only putting down 175HP at the wheels. a 2900lb ranger needs more than 180WHP to hit 93MPH on the 1/4 mile.
a 3.0 ranger is seeing about 125HP at the rear wheels (depending on year). thats good for about 82 MPH trap speed.
1/4 mile ET's, trap speeds, weight, and HP are quite accurately calculated from one another...so all these number are very close.
