computer problem
Cricket
everything on engine good wires module,sensors etc checked and tested everything engine light stays on cant draw a code disconneted batt. stil no spark # 2,3 pass, side out of coil pack[ new packs] light still on
this was actually covered by a few people over the years...
I just did a forum search on "plugs 2 and 3 not firing" or something similar, and came up with quite a bit of general information. Had to read through a few posts and check dates since I know I saw this not too long ago...
Anyway, this might be helpful...but you will need to read several posts to see if it's applicable...apparently the coil packs were wired incorrectly at some point and blew out the DIS module...
http://www.therangerstation.com/forums/showthread.php?t=68707&highlight=plugs+2+3
Hope that helps...sorry, I have a distributor and know very little about the DIS...and there have been a few changes over the years that mean parts are not necessarily interchangeable between model years...
icm good i purchased a new computer from auto zone will get it tuessday im crossing my fingers it will do the trick
