cwesterhouse
- Aug 8, 2012
i have a 1990 ranger with a 4.0 the previous owner swapped in a manual trans but still has the computer for the auto trans in it after about 6 months of driving it i started getting fuel pressure issues my pump will get 12volts to prime the lines then wen the relay cuts off it would go to 6volts i pulled the computer out and 2 capacitors in it were burnt up . also when i pulled the computer out the 6volts went away so do i need a computer from a manual ranger and would this cause my auto trans computer to burn up running it with a manual trans over time?
