Bnasty
- Aug 5, 2013
I bought the truck without the a/c working. found out there was no refrigerant in the system due to a leak in one of the hoses. Replaced the hose and had a friend at a local dealership at temp to charge the system for me. He then told me there no longer seem to be any leaks, but he couldn't charge the system because the compressor wouldn't kick on at all. Checked the current going to the compressor and wot relay and there's no power. I've been roaming through different forums all day. Decided to check current going to low pressure switch and there is none. Where do i go from there?
