sean9721
Last week I finally decided to fix the a/c in my Ranger. I replaced the orifice tube and charged it up. I have a little less than 1lb 9oz of freon in it. When I rev it up to 2,000rpm, the compressor will cycle every 5 - 10 seconds, like it's low on freon. At idle the low pressure was about 47. At idle, the high pressure was about 250. To me, those pressures are a little too high. But if I take any freon out, it will cycle more. When I rev up to 2,000rpm, the low pressure drops pretty quickly. The air blowing out of the vents is decently cool. Water is dripping from the evaporator. The lines coming out of the accumulator are barely cool when I touch them.
When I replaced the orifice tube, there was a decent amount of metal shavings in it. I am leaning towards a bad compressor. The low pressure switch is causing the compressor to cycle. It cuts off at 25. I can jump the low pressure switch and it won't cycle every 5 - 10 seconds.
I do a/c work on ambulances so I somewhat know how a system works. The pressure readings from my truck really have me confused.
