ItsA5Spd
Hi all, I'm going to to a compression test here soon and want to know what kind of PSI I should be lookin for. I think that it should be in the 110-130 PSI range, is that right? any help is great. Thanks!!
just hold the gas pedal to the floor while you crank it. this will cut the injectors and supply the cylinders with more air to compress (give you a better reading).
just the spark plugs to keep the engine from trying to start.
