junkfixr
reveals 180+ p.s.i. on all cylinders except #4 which is @ 175. No leak-downs detected but , does this sound high ? The outer white guage is p.s.i. on my scale but .... does this sound high ? What am I missing here ?
Still chasin' that one down. Had the ruel rail off & found no injector problems.
Did the compression test with engine cold, upper manifold off & inertia switch unplugged to rule out a cracked head / bad gasket scenario. Right at 145,000 miles now.
o2 sensor has been banged around from recent exhaust work. Cats are definately not clogged. Air & coolant sensors recently replaced, EGR working properly. Got the gut feeling it's not going closed loop, or the computer (EEC IV) itself is bad.
Sound familiar to anyone ? Mechanic used a code reader but gets no signal at the diagnostics plug so I'm gonna try the self test using a test light.
Just glad the engine is solid & that I found all the help & good advice here on the forum ! ! ! Other than "flooded" symptoms at cold start, it runs fairly strong, doesn't use or burn any oil to speak of. Just a fuel HOG... Rich, smelly exhaust & avg. consumption is 8 to 10 mpg's.
Tank & pump were just replaced, Dorman quick connects on the new fuel filter, had the rail off & checked the injectors...been drivin' me NUTS ! ! !
New exhaust from cat back, plugs,cap,rotor while they were all easily accessible. Yup, to say the least I've covered alot of ground. Code reader wouldn't work & had no guage for fuel pressure but since the whole fuel system was new I ordered a FPR. Turned out to be the cheapest part I've installed so far ($25 from Autozone) and wouldn't ya know it..
Ba Da Bing ! ! ! Runs & performs better than it has in the past year that I've owned it. I remember IMenriched saying that 90% of fuel problems result from the regulator, and it was the one thing I overlooked.
Didn't know a thing about fuel injection when I started this project but between the Haynes manual & largely from this forum I've got a much better understanding of what's going on. Thanks for all the help ! If I put a Ranger Station bumper sticker on it I'm hoping to gain another 20 horsepower !
