Complete Ranger/Bronco II Swap
willfixx2
Hello:
I have a 1984 Ranger with a 2.8 engine and I looking to put a 2.9 from a Bronco II with auto trans. Iwant to install the 23 gal. gas tank from the Bronco into the Ranger. Will that work?
What year is the B2?
The Bronco II is a 1988 model. The gas gauge on my ranger does not work because of a bad connection on sending unit. So since I was going to need a fuel pump for the swap I thought the would do the trick with an added increase fuel capacity. If the tank will fit, I will need figure out a new fuel door.
