"with the 410 cam what problems did you run into?"
I did a complete rebuild, and I didn't do enough homework on what was needed with the cam swap. I wasn't aware of the need to retune the ecu and from the start of the break in I was getting 'CEL' codes all over the place that didn't happen before. The fuel milage went postal and the motor was burning real rich. ( i am still waiting for the tune) obd1 is harder to get a tune for where I live. (and I have had to relearn to drive keep the truck at a constant speed under 60 to conserve fuel) however, when i want to pass a car or tromp on it she lets me know that its time to run. I also had to learn that this cam turns an average 1900/2100 rpm, something i wasn't ready for. I should have reasearched this aspect greater before the build. (live and learn). on these threads there is a ton of discussions about these 2 shafts, may I suggest you use the "search" option ^up top^ and type in 410 cam / 422 cam and read what has been written about. You didn't answer if you are tearing out and doing a rebuild or just a out and in swap. I guess the major of my probs actually in here came from people that were trying to help, however, they have not done this build and tossed me all over the place in different directions and it never occured to them that with this cam swap it was a tune that I was needing. so to actually say I had probs is a bit misleading. From all the reading about the 422 that I have done before the build that shaft is more intended for a higher compression build, as BigJim was stating.
