eric
- Jan 14, 2009
- Automatic
Hello All,
I have a 2001 2.3 liter 5 speed ranger. The transmission is not syncronized so its always been a bit difficult especially in cold weather to switch gears.
I recently had a new slave cylinder put in as well as the line going to master cylinder. Thsi was about 10 months ago and everything was fine.
Recently, when I press the clutch at say 3000 rpms , it takes a moment for the rpms to slow down enough so I can switch gears. Also, when I am at a red light or stop sign in 2nd gear with clutch pressed in at idle, the rpms drop and the engine stall. It does not stay at idle.
I checked the reservior and its full so no leaks. It does get a little better on warmer days and if I have been doing stop and go traffic. But when I go 30 miles on highway and then onto exit ramp, same issue. Its very tough switching gears and if I have to idle , it stalls.
When I pump clutch 20-30 times , I do have some success. Should I pump clutch with engine on or off.?
Also, what could this issue be?
Thanks in advance
Thanks in advance
