DeanMoriarty
- Jan 26, 2008
I'm having an odd problem, at least, it seems odd to me. I'm sure it'll make perfect sense to some of you here though.
I've noticed when it's very cold out lately, the truck acts a little weird going into gear, after I get going though, it's fine. A few days ago the temp got down well below zero here. I warmed my truck up for a good 25 minutes, got into it to leave, and the clutch went straight to the floor, no resistance, wouldn't go into gear. The slave cylinder was a little low, I added fluid, that firmed the pedal up a little bit, but not much, still wouldn't go into gear. I hitched a ride to work.
Today it warmed up above freezing so I went out to mess with it. I found that after I pumped the clutch several times, it got more firm and I could take the truck in and out of gear. Still, it's not as firm as normal and I have to push the gas when the clutch is barely released off the floor, otherwise it wants to die out. Normally the clutch pedal is about halfway up or more before I press the gas. It seems to drive now, and doesn't seem to slip or anything when it's in gear. I thought clutches would start slipping for a bit before they go out. Or am I dealing with a different problem here? Could it have just been low fluid combined with extreme cold? That's wishful thinking right? Thanks in advance.
