hey-you
- Mar 1, 2008
- Automatic
Hi,
I'm trying to understand here, and while I've found similar posts, if I could get confirmation that I've actually understood them that would be great.
Fan operation in cold weather:
1. it should come on at start up
2. it should freely spin (1/4 to 1/2 revolution) if pushed when the engine is OFF
3. at above 40mph 60 kph we're relying on wind or air movement not the fan.
4. at slow speeds we're relying on the fan for cooling if required.
5. the fan requires power and therefore may cause a drop in engine rpm when it switches off.
Correct so far hopefully.
The truck in question (in cold weather approx -20deg c) runs fine at higher speed but at slower speeds, it would appear that the fan comes on stays on for awhile and when it cuts out causes a 500-700 rpm drop (which if stationary can cause a stall).
So based on the above: the truck likely has a cooling system problem: ie either fan clutch failing or thermostat issues.
Fan clutch was replaced last winter... aftermarket parts so it could have failed.
Thermostat was replaced this fall after classic no heat issues. This combined with the truck registering normal temp on the dash (I know no precise but indicative) leads me to believe that the fan clutch may be faulty or sticky in cold weather... leading to when the fan comes on, it comes all the way on and attempts to do engine rpm speeds hence the noise and power requirement.
Correct so far? Yeah I know, in the time it has taken to type this I could probable get it fixed, but I'd like to actually understand what might be happening.
Comments on where I've lost the plot would help.
