Coil Springs...
Lpannell25
Well its got new shocks and new rear leafs might as well finish off the suspension for now and do the coil springs....
Come to the realization this is going to be my daily driver for now and will become a project truck later in its life so there for i need to get away from the whole lets make it a badass off road rig idea lol...
That being said i would like to get away from the whole lets jack it up idea (for now) and when i did the leaf springs i bought the universal lift kit just for the 4 ubolts inside as opposed to buying them individually... they came with a 1 inch aluminum block so i figure what the hell i want to use this...
so if i put that block in the back what would be the best plan of attack to level the front? order some stock coil springs from rockauto and use the washer method (stacked washers as coil springs) to level the truck precisely(i figure i can tweak it more or less if i use this method), maybe even buy some coil spacers? or should i try and get bigger coil springs instead of doing the spacers?
So its my understanding that you have a 1inch aluminum block in the back along with new leafs? for a total of 1" of lift? If its only an inch you could do the washer lift. for about that or you could probably do a full size explorer coil but that would probably give you more than what you want..
http://therangerstation.com/tech_library/WasherCoilSpacers.htm
no the blocks arent in but i have them... and im wondering when i do the coil springs when i put those blocks in the back should i just get oem coils and do coil spacers or the washer thing
If the front needs a little lift to level it you could either put a set of explorer 4door coils or washers. The coil spacers would probably be too much.
My new coils settled quite a bit.Probably whats going to happen is you will put new springs in drive them for a while with a rough estimate on height about 3/4 of an inch spacer with the back like you want it.Then measure them after about 2 months measure the height again and if it's off very far shim it again to get it closer.One of the advantages of the washer shim method is you can change it later.
