Coil Spring Help
Nosetackle63
Olympia, WA
Alright, so here is my problem.
When I first got my 1999 2wd 3.0 single cab Ranger, I cut the coils a turn and removed a leaf in the rear to lower it.
That is all fine and dandy with the weather here in AZ, but I am now moving to Oregon, where a lowered truck will not cut it.
My question is,
What coils fill fit in the front of my truck, what ones should I get to lift, and what would you reccommend as far as the leafs are concerned. I know I can flip the hanger and get 64" leafs, but is that the only choice other than blocks?
The cheaper the better, 'cause I aint swimming in money.
Thanks!
You could get exploder leafs, and not sure how much new coils are but I found some steel coil spacers for some quick height. spacers were 40 on e-bay and leafs were 20 from pic-a-part.
If you want 'cheap and lift' then why not check out the local wreckers and put stock springs back in and get some lift blocks? Maybe put up an ad on CraigsList for a trade? Or get a pair of spring spacers. You should be able to find those inexpensively on E-Bay.
EDIT - here you go, same thing goin' on here. Read up, learn, attack! http://www.therangerstation.com/forums/showthread.php?t=68466
