coil spacers +adjustable camber bushings
henryj10
Everett, WA
Want to level my 96 2wd 2.3L front end. worried about alignment and camber offset.
Was wondering if it would be worth it to install adjustable camber bushings that I keep hearing about after I level the front end with the spacers. Get the camber/caster to at least look right and then take it in and get an alignment to avoid paying 250+ dollars and waiting for the right bushings. I think some of the adjustables are +- 4 degrees?
What do you guys think? would that make getting an alignment simpler and cheaper/
Thanks,
Jason
Also does anyone have the parts number for the adjustable camber bushings that will work with my tib 96 front suspension?
it's alot cheaper if you install them urself. I got mine at napa, think they were 15 bux a peice or something. don't remember the part number.
i just got some for my B2 35.00 each 0+-3.25
as for the part number. go to the napa website.
