coil replacement
storey618
ive got new moog coils for my 86 b2, im still learning when it comes to wrenching so could someone give me steps on how to change them
thanks in advance
Jack the truck up and get it high enough that you can hold the front wheels at least an inch off the ground by putting jack stands under the frame. Since you are working on a BII it might help to back it up onto some ramps. That way you don't tip it over on it's behindus.
Then put a jack under the axle beam where the radius arm bolts to it, take the lower shock bolt out, and let the jack down slowly. Once the beam hits full droop you should be able to get the spring out. If you need a bit more space wrap a good ratchet strap through the spring and compress it a bit.
dont i have to take the bolt thats in the center of the coil on the axle beam off or do the coils just sit in there and the shocks keep them from coming out?
Yes, you have to take the lower bolts out. Forgot about those.
oh okay how long does it usually take?
How fast can you work?
Also depends on how much stuff breaks.
well stuff ALWAYS breaks on me so its probably gonna take a little bit. ill just put it off until next weekend and spray everything with wd-40 until then. thanks for the help guys
WD-40 is worthless for rusty parts. It is a lubricant. You need a penetrant.
Go get PB-blaster or BG InForce.
