Hi, i need some help. I have a 90 4x4 4.0 v6. Apon first starts when cold the truck will bog from time to time When shifted into gear or just start moving., Truck has newer injectors, new fuel pump ,New fuel filter, good fuel pressure, New iacv sensor, New tps,Etc.... No active cel but i will get one that is to fast for me to check and will not stay active, i jumped the connector and i got codes in the sequence 2-1-2-4-6-7 Twice then long pause and got a 1-4-1-9-6-1-4-1-9-6, I understand that it should be 3 digits but 212 is a tack erratic code, 467 doesn't show any codes following the code char here along with the next codes, Can Someone lead me in a right direction i am kinda lost. Thanks
