- Mar 6, 2020
- State - Country
- MI - USA
- Vehicle
- Ford Ranger
- 4.0 V6
- Automatic
- Total Lift
- 1-1/2 inch front leveling
- Total Drop
- Stock
- Tire Size
- 31/10.50/15
- My credo
- What's the worst that could happen?
176 | (M) Oxygen sensor not switching - system is or was lean Left or Front HO2S - Fuel control |
177 | (M) Oxygen sensor not switching - system was rich Left or Front HO2S - Fuel control |
I've searched thru the forum and ran across several strings that mention similar instances of contradicting codes and point to O2 sensors either being bad or not plugged into the correct connection (crossed).
RonD described symptoms he experienced, but with a different code.
Symptoms are:
Runs fine until warm.
CEL comes on.
Hard to accelerate unless you floor it
This popped up on me before when I replaced the heads and added headers. The headers had a threaded opening for an EGR connection. Since I don't have EGR, I plugged the opening with a 28mm pipe plug and some sealer. That fixed the problem until yesterday when it popped up again.
Any suggestions on what I might look for other than resealing the threaded opening -- which I will try to do tomorrow.
Is there a way to test the O2 sensors. I know "NEW" doesn't mean squat, but they have less than 100 miles on them.
Thanks in advance.
r
