- Aug 25, 2013
This is a long story but I wanted you to have all the info to help guide me in the right direction.
1. My engine was running rough, especially up hill or with a load. And some time would run rough at idle or acceleration. During acceleration it would buck a little.
-checked for vacuum leaks with carb clean = nothing found
-checked for grounded out spark plug cable = nothing found
-cleaned aci valve helped little
couple weeks latter bucking was getting bad again during slow to moderate acceleration code popped misfire on ? it was drivers side bank I remember that much.
-checked cables = all good -cleared code still running a little rough, but some times where better then others
-gave aci valve a good clean = seamed a little better but ran a little rough and less bucking
-no more codes
today got a code for misfire on #3
-switched injectors #2 with #3 cleared code went for a drive got #3 misfire again (not injectors)
-tried to switch sparkplug cables #1 with #3 to see if the cable was bad = crank no start, then start ran supper rough for a couple of seconds then died
-swapped cables back = ran as rough as before when I got the misfire #3 code.
-cleared code
-drove home 1/4 mile CEL on got 0353 code checked electrical connections, all tight cleared code again got 0353 again
-cleared code got new coil pack still ran rough code 0353 again
any thoughts
-no more codes
-cleared code
any thoughts
