Kyler-
- Nov 19, 2009
I ran the check engine test and got codes
67-Transmission Manual Lever Position (MLP) sensor circuit - Transmissions
(M) Intermittent Park Neutral Position (PNP) sensor fault - PNP
22- MAP (vacuum) or BARO signal out of range - MAP
41- (R) System lean - Fuel control
(M)System was lean for 15 seconds or more (no HO2S switching) - Fuel control
Should I just replace the tps sensor and the map sensor?
Truck idles low and hesitates at low rpm
