barrys
Just thought I'd ask...
It's a 1994 Ranger V6 3.0 with auto trans.
I had a lame smog result -- passed but not with flying colors -- high HC and medium high NO.
I read up and did the KOEO and KOER tests and got these results consistently and repeatedly:
335 (KOEO) EGR sensor circuit voltage higher or lower than expected during self-test
336 (KOER) EGR sensor circuit voltage higher than expected
336 (KOER) (Trucks ONLY): Exhaust pressure high
I got those code defs from the Equuis scan tool manual.
Not sure which 336 definition I should go with.
The truck is running fine, idles fine, and no other codes were thrown from either test repeatedly. In one test, I _think_ I saw a 328 -- EGR closed voltage lower than expected, but I could not get that to repeat.
But, I'm not sure and never saw that again.
Then, I read up some more and did a voltage check on DPFE and saw (KOEO):
VREF: 5.0V
DPFE: 1.29V
Started with cold idling engine:
DPFE: 1.86V
Based on reading, the DPFE is most likely to fail out of all the EGR components and those voltage tests show a failing DPFE.
So, replacing it seems straightforward enough. But, what is actually happening when the car runs with the DPFE functioning like this? Is it a real problem with how the engine runs or strictly an emissions problem. I'm not one who likes to pollute, so I'll try to fix this no matter what. But, you guys are so ontop of this stuff, and I would enjoy a little more education.
The last time I worked on cars, I could not even spell EGR which was OK since that car had like one vacuum tube and the exhuast went right out the tailpipe...
VREF: 5.0V
DPFE: 1.29V
DPFE: 1.86V
