richard99
- Feb 5, 2008
- Automatic
1995 4x4, 3.0...
Just replaced the trans and slave cylinder. I'm in the process of bleeding it now. I've read all the posts, and they're right. This process is a b***h. Does anyone know if there is a SURE FIRE way to bleed the bugger right, first time? I've got a steady stream of fluid coming out of the bleeder valve, but the clutch is still just engaging right near the floor.
One more, please: if the clutch is disengaging correctly, should I be able to grab the output shaft and rotate it?
Exasperated in Maine.
