Clutch problems
Lrpalo
I was on my way home and i started having no pressure from my clutch pedal. I was low on fluid so i topped it off and went to bleed the system and i cant get any fluid to come out, even pressurizing the reservoir i couldn't force any fluid through even with bleeder screw right out of it. My guess would be that either my master cylinder or slave cylinder are bad but the slave was done about 30k ago when the clutch was done. Anyone have any ideas?
Do you have fluid on the bottom of your tranny's bellhousing? Sure sign of a bad slave.
I had a fun one when I reused the master cylinder out of a 92 exploder - was trying to bleed the system after an M5OD swap and couldn't get a pedal. Got down in the floor to watch the master cylinder pushrod and actuated the clutch pedal by hand. LOL that sucker was shooting brake fluid out of the back of it. Sure made it clear where the problem was!
