Not sure if you fixed your problem yet. As far as master/slave combo, I'm running an 89 v6 master cylinder with an 83 diesel ranger slave cylinder. My truck is a 97 and like teddyzee's had to cut the piece off that the factory master mounted to and mount the 89 master to the firewall. When I had the stock 97 master in, I was using a CJ pony performance slave. Took me a week to get a pedal out of the truck. I bled it for a week straight and still the pedal would go right to the floor. I wasn't bleeding it right. Pull the master out and leave the line on it. Cap off the end of the line where it would attach to the slave and make sure it's air tight. Tip the master so that the rod end that attaches to the clutch pedal is facing down. Fill the reservoir, grab the rod for the master with it still facing down and start pushing the rod into the plunger. Short strokes. You will start seeing bubbles in the reservoir. keep doing short strokes until it is hard as crap for you to push on that rod anymore. You will feel the difference. Once it is hard to push, the master is bled. Put the cap and rubber piece back on the reservoir and tighten. This will help so that when you uncap the line to reattach it to the slave, it won't get air back in it. Remount your master and connect the rod to the pedal. un cap the line and connect it back to the slave. Open the bleeder on the slave. Now uncap the reservoir again and fluid should start flowing through and out the bleeder in the slave. let the fluid flow out of the reservoir until it gets a little past half. Do that about 3-4 times. The final time, once it's at half full, close the bleeder, recap and put the rubber piece back in the reservoir, then you are done. I did this and after a week of fighting with it, it was bled and ready to go. Hope this helps u.
