ZakV
- Oct 29, 2012
Hi all,
I've figured out a few issues I have, and they're all to do with my clutch! I have firewall flex in my 1990 Ranger Custom, and due to that I have lost all the bottom end of my clutch. To make things more interesting, my slave cylinder is leaky so it needs to be topped up and double pumped now and again. (Before the firewall flex got as bad as it did anyway, now I don't even have clutch) So my poor ranger is parked at where I work, which luckily has all the tools I need to regulate the situation. My plan is to bolt in a piece of 14 gauge steel on the inside of the truck, disassembling my pedal assembly and fitting it to the right dimensions. From there, I was considering replacing my slave...but there sure is a lot of work involved in that, and I was told by a mechanic friend I might as well put in a new clutch while I'm at it. Seriously, is there anything that's working on my clutch??
Anyway, do you mindful and experienced folk have any experience with this? Thanks in advance, I'll try and post pictures once I start.
Cheers!
Cheers!
